I broke my timing chain..
For some reason i got stupied on my build and put a stock timing set on my new motor. Has any1 ever broke a stock timing chian? Also should i pull my heads off and have everything checked out? What timing set should i go back with? Its a 94 with non vented opti.. Thanks guys
I use to run a stock timing set on my 383. I never had any issues and the car made 446 on the dyno. I was probably just lucky though. I switched to a vented style opti just to run a double roller on my most recent build.
Moderator
I've always used the Cloyes double roller (must use an electric waterpump though). Part number 9-3145. If using an electric pump is not an option, the LT4 extreme duty is a good alternative, albeit a bit pricey.
You are just asking for problem with the stocker. Not only is it quite weak, but it ALWAYS has too much slack (even when new).
I am using a ewp.. So the 9-3145 ill work on non wented opti's.. also should i pull my heads
If you are using a non-vented opti, stock is about all you can use. The only aftermarket spline drive timing set I ever saw was from Doug Rippie Motorsports and it was extremely expensive. Not sure if it is even still available.
Unless you are willing to part with a pretty decent chunk of change then you can really only go stock and cross your fingers. At your power levels you should have been fine, but **** breaks in racing, thats the name of the game...
I am switching to the EFI setup and running a 3145 cloyes(which I sold a brand new one for cheap thinking I couldn't use it before they released the TPIS timing cover )
I've heard time and time again people say that the stock timing sets are plenty strong for most builds. But reasons like this I don't believe it. This isn't the first time I've heard of a stocker breaking, I had one break back in 2005 on a 94 that had a hotcam/LT4springs combo. But that one broke at high rpm, and bent just about every valve in the engine. Also busted a BIG hole in the side of the timing cover.
My best advice to you is to pull your heads, inspect for damage, and like Jason said, convert to a vented opti and buy a good timing set.
Ever since my experience with this back in 2005, I run a billet cloyes hex-a-just in my own car. And I've had good luck using Progear timing sets a couple of H/C cars I've assembled.
Anticipate requiring both replacement valves and head machine work. It is unfortunate, but it is an opportunity to do something w/ the head if you're so inclined. Good luck!
when i first had my 383 built i had a new lt4 chain break on me and bent a couple valves......mine was because of the waterpump gear.....i put in an electric wp and left the gear in the timing cover which eventually slid forward and rubbed into the chain...when i redid everything just took the gear out and put in dbl rollers.....so you may want to check the gear drive from the waterpump and if your running an ewp just remove it
I went with the Cloyes "true roller" double roller timing chain for my 383 rebuild. I've got the exact part number at home somewhere. The kit cost like $80 or $90 bucks if I'm not mistaken (maybe less!). I had always planned to go with the Meziere electric water pump conversion so the double roller made sense.
Have any of you guys seen timing "kits" comp cams makes for LT1's??? The prices are freakin INSANE - like $500+ for timing sets. I don't care what they are made of, the costs are just outrageous. I think one of their selling points is that its a double roller chain engineering to work with/retain the cam driven water pump feature (I think). Otherwise who the hell would pay that much...
What does an "LT4 extreme duty" set go for? That's a few bills itself isn't it?
Anyone thinking of doing an electric water pump conversion should consider an old school (SBC) double roller setup.
