Damn exhaust leaks
Old 12-12-2010, 08:08 PM
93zmaro's Avatar
Default Damn exhaust leaks
Some jackass broke a few exhaust manifold bolts in each head and it happens to be the furthest to the back. So my question is wats the easiest fix for this problem. Remove the heads and drill an tap or hopefully someone knows a better way.
Old 12-12-2010, 09:08 PM
lt1slowz28's Avatar
EZ outs
Old 12-13-2010, 03:27 PM
Burning Rubber's Avatar
I have found it easier to take it apart the first time, rather then fight with it and then find out I have to take it apart anyways. lol
Old 12-13-2010, 08:32 PM
jaycenk's Avatar
I'm with him. There is virtually no way to get a drill in there
Old 12-14-2010, 12:46 AM
VinR1's Avatar
Sounds like you bought your car from the same guy I did
Old 12-14-2010, 07:58 AM
Formula WS6's Avatar
No one broke the bolts off on you. From the stock manifold expanding and contracting it puts pressure against the bolts and causes them to snap. Your best bet is to get a angle drill (90*) start with an 1/8th in bit and go larger from there. Just be careful to not put side pressure on the bit because you'll most likely be pulling the head to get out a broken drill bit. Reverse drill bits work nice and I've gotten lucky to where they've actually backed out the remaining bolt. Good luck cause no matter what it's going to suck.
Old 12-14-2010, 06:56 PM
93zmaro's Avatar
Yea sounds like its really gonna suck. Thanks 4 the input
