What would you pay for a forged 383??
Well I found a brand new forged 383 short block with a Forged eagle crank and H-beams, 11.1 SRP forged pistons gapped for spray. ARP head studs &mains ARP rod bolts, Motor was done by a prof race shop and only has engine dyno time on it.
What do you guys think its worth????
What do you think my 353 is worth???
My motor
About 500 miles on it now and runs perfect
ENGINE BLOCK=Hot Tanks/bead cleaned
Hone&bore .020 over
Torque plate bore service
Line hone mains
OE cast crank shaft cut 10/10
OE connecting rods reconditioned
fully balanced assembly
Clevite bearings mains/rods
Speed pro forged pistons 10.1 compression
Seal power molly rings
ARP rod bolts
New freeze plugs/gally plugs
My motor
Hone&bore .020 over
Line hone mains
ARP rod bolts
Ill sell mine for 1k but would like a local sale as I know shipping will be a biatch. Ill also sell my 4bolt block and a cola crank also. If anyone is interested PM me
1k for my short
350 for the crank never been turned
300 for the 4bolt block .040 over.
I should even sell my t56, street twin, fly wheel, Mcleod ajustable master and pro 5.0 shifter while Im at it.
1k for my short
1k for my short
1k for my short
There is a pic in the mag you can see my 1/4 panel lol Always lookin forward to meet the guys I talk with everyday!! Its a damn good time at the shootout.
Im making a for sale thread in the classified section and the midwest classified section. Lots of good stuff!!!
My Short block
my 4 bolt block
the 3.75" cola crank
New assembled Dart 200cc heads that have been worked
true double roller
cam
N/O plate kit
pro mag lifter
crane gold 1.6 rockers
Canton fabbed VCs
accell injectors
new 95 GM opti
stock intake
95 pcm and harness
AC delco water pump
My Short block
my 4 bolt block
true double roller
cam
N/O plate kit
pro mag lifter
Canton fabbed VCs
accell injectors
new 95 GM opti
stock intake
95 pcm and harness
AC delco water pump
