what's this? 1 Attachment(s) hey guys. so I dropped my steering wheel to make my header install go smoother and it was actually pretty simple and a pretty big space maker. I went to put the wheel back in and I see this cable with a white tip marked "Up Up Up" floating around back there behind my cluster. i'm just wondering what it is because I think it might need to be replaced. here's a pic: |
looks like a bracket from the dark picture. kind of like it has a nut indentation on it but hard to say |
does you car have cruise control? |
Originally Posted by 96TransAmboosted
(Post 14568516)
That looks like the cable that connects to the steering column on one end and the automatic shifter on the other end. I think that cable is what prevents the car from starting when it is not in park, but I am not certain. |
100% positive thats the cable that prevents you from removing your key when the ignition is in any other position than off and your transmission is not in park. |
Originally Posted by marc1130
(Post 14571998)
Originally Posted by matman88
(Post 14568424)
hey guys. so I dropped my steering wheel to make my header install go smoother.... |
Haha ya. 3 of my manifold bolts blew out... that's why i did the header install in the first place. because i get 2 new holes with headers. But I still had a bolt I needed stuck in the head flush with the surface. I dropped the wheel so I could get a 90 deg drill in there with a reverse bit but had no luck so I'm going to put it together with 5 bolts (better than 3) and see if there's a bad leak. If I get a leak I will have a shop pull the heads and drill it and tap a new hole. Whole process has been a nightmare but I'm treating it as a learning experience. Big thanks btw for all the help. finally got them in and now I just need to finish putting everything back. |
That cable locks into the column halfway up in a black box, it's hard to describe. |
(Post 14572181)
Originally Posted by SS RRR
(Post 14572332)
Once you get the exhaust out of the way the drivers side cylinder head is cake to remove. |
The cable inserts into the back of the ignition switch. |
(Post 14573520)
don't you need to take off the intake manifold? I don't have the tools for that. I'm just a college kid with a Huskie tool kit lol. |
Originally Posted by leadfoot4
(Post 14574933)
Other than the tool to release the fuel supply and return lines, a couple of sockets and open end wrenches are about all you need to remove the intake, and a couple more sockets and extensions get the cylinder head off. Working on a SBC is pretty straightforward... |
The water pump does not need to be moved there is at least one bolt that goes thru the accessory(sp?) bracket in the passengers side head that has to come out. Only basic tools are needed along with a good torque wrench. Also don't forget about the water lines thats connected on the rear of both heads. |
Originally Posted by riceburnerZ28
(Post 14575263)
| All times are GMT -5. The time now is 08:33 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
