tube from head to head?
I've noticed that there's a little tube that went from one head to the other on the back of the motor. what is it? what does it do? is it needed? and if so where can i get one? i remember seein a thread about this but don't remember the outcome and cant find the post.
It's part of the reverse coolant system that LT1's have and is vital to correct operation of the coolant system. You can get a new GM but they are spendy.
I know there is a few threads about how to make one from AN fittings and hose. just do a search. Its called the steam pipe usually.
You ABSOLUTELY need it. It's called the "steam tube" or "coolant crossover tube". It is necessary to relieve pockets of steam and coolant from the heads, the coolant flows from front to back on an LT1. It routes the coolant and steam back to the radiator.
You can replace it with barbed fittings and rubber hose, -AN fittings and connectors, pretty much anything you want that will take hot coolant for years to come.
I have NPT to -6AN fittings on the back of my heads, with -6AN push-lok hose to a -6AN tee, then up to the radiator. The -6 push-lok hose is the perfect size to connect right to the radiator with a hose clamp.
^^^how much?
i just found this thread.
https://ls1tech.com/forums/lt1-lt4-m...-pictures.html
only thing i don't see is where it goes back to the radiator
dude, follow the line lmao. It hooks into the radiator JUST ABOVE the radiator hose on the left side...JUST BELOW your Radiator Cap. Not the one that runs to your overflow tank, bt the one just under that
