'93-'94 coolant hose 'upgrade'
I tried searching with no luck
my '93 sprung a leak in the upper hose that runs from the heater core to the water pump - its just past the 'T' that goes to the throttle body. Since I'm having to replace it anyway and my TB is already bypassed, can I just get a '95+ upper heater core hose (without the T) and a '95+ driver side radiator hose (also without the T going to the TB) and replace both? If so, any issues?
THANKS,
THANKS,
I believe everything will work just fine. I just replaced that same heater hose ***'y on my 93 and now I wish I would have used the 95+ stuff to delete the TB coolant deal.
