Removing PCM to go XFI... BCM still work?
I'm going to a FAST XFI system, and I'd like to remove the PCM and engine harness completely. Will the BCM still operate normally? I'd still like to have all the interior stuff working (I know the gauges won't work).
What would I need to do to make everything work correctly? VATS?
Thanks!
Thanks!
i did this on my car.........i built a fully standalone harness for the xfi and engine.....the BCM will work still but you will have to jump power and ground to a few places to keep it functional...my power windows, power locks, lights, wipers and all gauges except tach and speedo still work perfectly..also your theft start relayy will have to have ground supplied to the side that goes to the vats module......you can remove the vats module........heres some pics of how i did mine..........
injector harness
this is it all done........all of the wires are hidden and everything is nice and neat and simple looking...
injector harness
Thanks!
Thanks!
Ok guys, I'm finally getting started on the wiring nitemare. I HATE WIRING!! lol. So my first question is, on a stock car, there are 2 connectors on the top of the passenger strut tower (C100 and C105). These and all the associated wires can be removed, correct? From what I can tell they are power feeds to the PCM, and control a lot of the things in the fuse/relay box under the hood, like coolant fans, A/C clutch, TCS, Cruise, etc.
I'm removing everything except the lights and horn up front. The fans, WP, and other stuff will either be controlled with the XFI, or through an ARC switch panel.
HELP! lol This stuff gives me a headache!
