My cut outs are in!!! Questions before the install.
I got two dmh electric cut outs. The low profile ones if it matters. Now the directions are scarce at best but from what it looks like. I get the exhaust shop to cut and weld up just the cut out to my y pipe. Then hope i make it home without the man on my *** (since the cut outs will be open at this stage) then get it home and bolt up the valve with the sealant and turn down piece dmh provided, correct? Anyone know why it seems they included what looks like 2 block off plates in the package? I can't figure it out. They look like block off plates for the cut outs but i don't know why. Thanks, this is my first cut out install!
The block off plates are to block off the flanges in a case of a motor failure or as you are doing ( driving home without motors )
you must have the cutouts assembled to properly fit them
I would also suggest bolting on the block offs during welding to help keep the flange true during welding.
