HELP!! need body harness pinouts ASAP.
I'm needing a pinout of the main harness connector under the dash of a '95 LT1 Pontiac. (idk if a camaro is the same or not). The large connector that comes through the bulkhead in the firewall, and has one 9/32" bolt clamping it together.
While i was ditching the ABS, air bags, and cruise control, I accidentally removed the white tach signal wire that runs from the c230 connector (cavity D) in to the bolt together harness connector under the drivers side of the dash.
Shbox.com has all the engine wiring diagrams, but I can't find this specific connector.
Any help would be greatly appreciated!
The tach wire does not go through that side of the dash or that large connector. It goes from C230 to the cluster. C230 is on the RH side of the dash from the PCM.
So then maybe I'm worrying over Nothing then?
Btw, your site, coupled with the ls1 pinouts available, have been very helpful in repinning my lt1 car, for an lq4
