will 6 cylinder harness for engine bay with fuses?
work for 8 cylinder car? I know the fuse box will have less fuses than a Lt1 car but will they work. Or are they entirely different.
Does anyone know for sure?
Its just the harness from the driver side bulk connector and all the wiring that controls the headlights, cruise control, fans, etc.... with the big fuse box
lmk guys
thanks
lmk guys
thanks
I think what he's referring to is the Injector Power Wires..all the Injector Control Wires are in the Harness.
The V6 Car has only one wire in the Fuse Box to power the Injectors & Coil, for the V8 Car you have to add a second power wire to power Bank 1 & Bank 2.
Everything on the Engine is controlled by the Engine Harness..pretty much what you connect on the Wheel Well is power & grounds, and the Serial Data Wire.
