LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Trend PR's arrived today (https://ls1tech.com/forums/lt1-lt4-modifications/1469438-trend-prs-arrived-today.html)
Puck Sep 22, 2011 04:38 PM
Got my Trend PR's in the mail today, a few days earlier then expected. They were ordered on the 12th, and I got them today on the 22nd. 8 business days is not too bad for custom order pushrods. Their customer service was great.
They are 3/8" .135 walled with 210 5/16 ends, 8.130" long. Here is one next to a ballpoint pen for reference - they are toddler fingers :lol:.
http://img809.imageshack.us/img809/6394/trendprs.jpg
AChotrod Sep 22, 2011 05:30 PM
Beefy! So does that mean the heads are on the motor already?
joelster Sep 22, 2011 05:49 PM
Those are some long pushrods! Are you sure you don't have a big-block? LOL. I ordered mine from Trend as well. Great company to deal with. I got mine in 3 days though! Those things must weigh a lot!
Puck Sep 22, 2011 06:14 PM
They were mocked up to measure PR length and test PTV then removed, and but I haven't gotten to install them properly yet.
3 of the head bolts on each side need the springs to be removed first, and I've been procrastinating because of that. Having to pull springs to install head bolts, what a PITA huh? :(
The valves and springs are pretty long and the shaft mount pedestals are tall. The length is one of the reason they are .135...if they were shorter I probably could have gotten away with a lighter thinner wall. They weigh a ton! I'll trade more lobe side weight for stability any day though...
I am way down in FL and mine were custom length, so I had to wait for them to machine them then ship them literally across the country.
Tuesday if my day off so I'll try to install the heads/intake and set lash. I am going to run the taller port LT4 race intake gaskets for now, but have an idea for that as well that I will be testing once its together :secret2:.
joelster Sep 22, 2011 07:32 PM
Take a grinder to the head bolts in question. Some of them flare out to the mating surface too wide. If you install them then put the springs on, the springs might bind up if they make contact with the bolt. I had to grind one of the washers down and slightly grind on one of the nuts for the nut to be threaded on the stud in the centermost bolt.
Puck Sep 22, 2011 09:12 PM
The bolts don't physically fit between the springs since they are so wide. Its not the height of the bolt head, but the diameter of it...
joelster Sep 23, 2011 06:18 AM
I know. Try running a stud with a 1/2" 12 point nut. It will still need to be trimmed down a bit.
quik95lt1 Sep 23, 2011 07:29 AM
ugh that sucksssss what OD diameter spring are you running......glad to hear your getting close though!!!!
what the hell are you guys running for bolts/studs and springs?? lol mine were close but they fit and i ran the same head stud kit you did from arp.......
Puck Sep 23, 2011 11:27 AM
Ill Mic the OD when I get home, they are pretty beefy. The bolts are normal felpro, but I may look into a stud kit.
Puck Sep 23, 2011 03:59 PM
They are 1.55" OD.
joelster Sep 23, 2011 05:56 PM
Mine are 1.550" od as well.
This is what I did to the center washers:
http://inlinethumb38.webshots.com/45...600x600Q85.jpg
Then I just put the nut onto an extra stud and ran it over a grinder for a minute to make the flared out section a shade narrower. Fits like a charm.
Puck Sep 23, 2011 11:34 PM
Do you have the PN for the stud kit you used? I'm not sure if the heads on the felpro head bolts will fit even if I grind the flared part. I haven't looked at it all together in a while tho so ill have to take a second look and see what my options are.
If I can find something I can use without pulling the springs to install the heads then I wouldn't mind spending a little more for that ease of assembly - if I end up having to pull the heads later for a gasket or something ill be glad I did.
joelster Sep 24, 2011 07:10 AM
The stud kit came loose in a box when I bought the shortblock so I don't have a part number. I did a quick search on summitracing and found this:
http://www.summitracing.com/parts/ARP-234-4301/
That looks to be the exact kit. Keep in mind that I didn't use the top row of studs. I had to purchase a bolt kit as well since the studs can't be used where the shaft rocker mounting base attaches to the cylinder head. Use teflon tape and a small dab of sealant when you use these studs. I had 3 of them weep coolant on me at the shootout. I took them out and used teflon tape and a dab of liquid and haven't had a problem since. 2 people at the shootout told me it's common to have ARP studs leak. I did a google search and found that people have sucess with the tape moreso than the liquid. If I get some ambition this winter I will redo all of them.
Just so you know you can purchase studs individually. You don't have to buy the entire kit. Maybe you will only need 2 of them for the center bolts.
Puck Sep 25, 2011 12:58 PM
Just checked everything and it looks like i will be fine just trimming the flare off of 3 of the bolts on each side. Not going to bother with the studs.
Thanks for the info though guys :).
joelster Sep 25, 2011 06:41 PM
If it doesn't work let me know. I have extra studs sitting here with washers and nuts. I can modify them and ship them out to you, just repay me the shipping cost.
Puck Sep 25, 2011 10:23 PM
Thanks, hoping to get some work done on Tuesday on it and I'll let you know how it turns out.
I'm thinking I wont need them, but if i do I'll let you know - thanks a bunch for the offer either way.
quik95lt1 Sep 26, 2011 08:12 AM
i run the same ones joel......same deal for me the top row are the jesel bolts because they go under the shaft.......i brakekleen my studs and threads before installing and use some black rtv on the threads and i havent had any leaking issues......you shouldn't need the tape......just gotta make sure the bolt is perfectly oil free before install or the silicone wont stick.......thats usually the problem........i remember i did trim a couple of washers to fit but they did clear my springs.......the spring i run is only a 1.46" OD though.........you guys are running some big ass springs lol
SS RRR Sep 26, 2011 09:36 AM
What head bolts are you using? I am running a 1.55" spring with an ARP 1/2" heat bolt and I only had to grind two of the washers.
Puck Sep 26, 2011 09:56 AM
They are the plain SBC Felpro ES72856 P/N. I used them on my last setup without any issue, but with a beefier valvetrain, aftermarket heads, and shaft mounts things are quite a bit different. It looks like the middle and both ends will need to be clearanced, both the washers(that I still haven't relocated yet, they might have ended up in the box with my supervic) and the flared heads of the bolts.
Hoping to have the physical motor fully assembled tomorrow w/ intake and everything, then its just 3 main things left - fuel lines+AFPR, damper, and the expensive part...whatever computer/harness I go with. Still tossing around between the badass 24x setup or a much cheaper junkyard Vortec 411 setup. Will probably go 24x and pickup a good condition harness to repin myself for ease of setup - it looks like a killer kit.
At this point I'll probably miss the good weather...we only get like 3 cool months down here(which haven't started yet, its still 90*) then its hot as balls again.
quik95lt1 Sep 26, 2011 09:59 AM
man u guys are all running big ass springs lol.....
© 2026 MH Sub I, LLC dba Internet Brands
