#7 won't fire My friend has a 97 30th anni. Z-28 I has hooker headers, intake, ORY, and other things. We have changed the plugs in it and done a compression check, and injector check, for some reason #7 will not fire. I know nothing about LT1's so any ideas would be helpful. |
check the wire to make sure it isn't fried (you've probably done this already) and check the opti. |
We checked the wires how can you check the opti? |
You could use a spark plug tester, or just a good spark plug, to see if your getting spark to #7. Also you might want to inspect the plug (if you are getting spark). I had a hairline crack in the ceramic material one time which caused it to miss. Hope this helps. |
Thanks for the info I'll check the opti because it can't be anything. |
| All times are GMT -5. The time now is 03:02 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
