Long tubes with y pipe and cat
I have a 94 z28 and was wondering if I put the stock cat basically on the end of the y would it still do the same thing? Does it matter that it's farther from the motor? I live in Cali and basically I just want it so if a cop looks under, I still at least have a cat. Also anyone know any 50 state legal cats for a good price? Thanks.
Village Troll
Depending on the cop, even if he/she sees the cat and it actually functions you can still be written up because it is illegal to tamper/move a catalytic converter from its stock location. The most effective way to get around this for a OBDI car is to get mac mid lengths, have y-pipe fabbed and flange a catalytic converter in the stock location. That way you can run a flanged straight pipe when you want. I bet it would yield far better results than if you were to go LT's w/ even a dual cat y-pipe. Cheaper too. Many many used to run this setup on their OBDI cars years ago and were in the 12's with bolt-on's.
Edit...
http://www.macperformance.com/store/...roduct_ID=1444
There you go...
Edit...
There you go...
What if I had a shop cut and weld one about the same spot it was in originally? Edit:nvm I see you seggested that, I know the stock ones smaller inlet and outlet but do they have 2.25 or 2.5" to 3" connectors?
Village Troll
Ew... I think you would be much better off going with a dual cat y-pipe then. Unknown what will happen when you have to get an e-check...
