CC 467/XFI 280 Numbers
What else do you have done. That seems like a big cam for a stock head car. For a H/C/I car I'd say if you match the stall for it, then it might do you well but street manners may be a little degraded. I'm not a genius like some of these guys though so I could be completely wrong.
I've noticed that a lot of people make a big deal out of sweating their cam specs. Honestly for mine I talked to a couple guys that had proven setups here locally and had a ballpark where I thought would be good and then talked to Lloyd when I sent my heads off to be ported and his ideas came out pretty dang close so I went with his idea. I wound up with LE2s and a 224/234 .597/.613 on a 110 with 1.7 rockers. I'll let you know how it comes out. The install is almost done. I'll be exstatic if I hit anything higher than 380 even though I have hopes of 400 at the wheels.
Well my mods are in the 94 below... im pretty happy with how it drives just dissappointed in the numbers it put down. This is an emissions build so i have to keep that in mind. Biggest emissions cam Lloyd has successfully passed was a 226/232 112lsa cam. I figured with the Comp 230/236 113lsa the lsa would help being able to run the bigger cam. I have the compression, headflow, and gears to make this cam work properly. I was looking to do some research to see what kind of power guys were making with this cam. Trying to stuff the biggest cam i can in this motor and still pass smog and hit 400rwhp.
