Need help!
Old 04-12-2012, 11:39 PM
Hector Medina's Avatar
Default Need help!
Hey guys, im new to this forum and need some assistance! I just sold my Speed6 and decided im going to drop 4k on my brothers 95 Z28 for fathers day. What should i buy? I want it to make reliable power and at least make over 350.
Old 04-12-2012, 11:55 PM
rich5368's Avatar
Start with a stall if it is auto. Then gears. Then intake headers cutout tires. That'll put you around 300. You want 350 you'll need a cam swap. You'll get a lot of opinions on what can to use but I recommend a small custom grind on stock heads. That will put you around 350. Add some spray and it'll be a boss. Bolt ons and a cam and you can plan on anywhere from 2500-4000.
Old 04-12-2012, 11:59 PM
rich5368's Avatar
Better yet do your stall gear boltons tire and suspension. Then go from there. Wish I'd have gone that route.
Old 04-13-2012, 12:00 AM
He already has the gears done. Whats stall? I have no experience on this platform, haha sorry for being a newb! He hates spray, any alternative?
Old 04-13-2012, 12:07 AM
rich5368's Avatar
If its an auto you'll need a stall converter. You can read up on them on the web. I'm not great at explaining stuff. If he's got gears then I'd personally finish the boltons get tires and suspension and go from there.
Old 04-13-2012, 12:08 AM
Can you recommend me a good vendor?
Old 04-13-2012, 02:57 AM
zooguy's Avatar
i love my vigilantly 3200 stall ... a warning about a stall ... at low rpms (1000-2250) it kinda feels like your driving in the mud. BUT as you get closer to the stall speed the car COMES TO LIFE BIG TIME.
all auto cars have a torque converter and from the factory the stall speed is about 1800 rpms (very low) this makes it so you dont need as much throttle to get going quickly. now by upping the stall speed to a higher rpm range (2800-4000) it will allow you to bring the rpms higher before the car wants to pull hard.
so a stock auto car you can foot brake (gas and brake at the same time) to bring the rpms up to about 1250-1500 rpms right? well by bringing up the stall speed you can bring up the rpms to a much higher point that is closer to the torque and hp peaks. kinda like how manual trannys rev the motor before the dump the clutch. now your not going to have to rev it to the moon to start moving but a few more rpms will be needed to get going at a normal pace. with my car as an example i have a vig 3200 and i usually run in the 1500 - 2000 rpm range to "keep up" with traffic.
on launching my car now that i have a stall i can bring up the motor to about 2400 to 2550 before the tires start to spin. i have street tires on it now and i have not tried to load the stall up yet with a set of sticky tires. but i bet i could get a little higher with more traction.
hind sight is 20/20 and i wish i had got my stall sooner.
Old 04-13-2012, 06:45 AM
bowtienut's Avatar
Some good info on torque converters within this website:
www.converter.cc
Yank is one of the best brands.
Go with a 9.5"-10" converter. No worthwhile gains with a 12" for that car.
Old 04-13-2012, 01:21 PM
WS Sick's Avatar
Well the 12 inch converters make very nice transmission fluid heaters.
Quick Reply: Need help!
