LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   I'm fed up with this! (https://ls1tech.com/forums/lt1-lt4-modifications/1551489-im-fed-up.html)
FocusVince May 29, 2012 05:58 PM
Alright, this car is running so bad and I've tested fuel pressure, replaced the ICM, cap and rotor, coil, fuel filter, and plug wires. The damn car won't throw any codes, it stumbles under high load especially in the low rpms, it barely idles, constantly misfires, and it gets even worse when it warms up.
Someone please help, what the fick is wrong with my car?
96lt1m6 May 29, 2012 06:28 PM
Unplug your o2 sensors and see if that changes the way it runs. How did you determine the car is not "throwing codes" not seeing a check engine light does not mean no codes have been set......
lt1-xjs May 29, 2012 07:07 PM
You don't mention the plugs, new, old ? Low rpm, high load miss could be a cracked plug.
nitrous2fast May 29, 2012 08:47 PM
What do you have the plugs gapped at??
FocusVince May 29, 2012 09:54 PM
I don't know what the plugs are gapped at but they have been in there awhile and I don't recall having this problem before. Perhaps it is a cracked plug but I have touched them recently so I"m not sure how they would become cracked. I'll take a look at the plugs tomorrow.
FocusVince May 29, 2012 09:57 PM
Is there anything else I should look into while I'm working on it tomorrow other than plugs?
LT1FirebirdSLP May 29, 2012 10:25 PM
Opti.
96lt1m6 May 29, 2012 11:21 PM
Don't overlook the O2s
94LTZ May 29, 2012 11:24 PM
My car ran like ass and didn't want to idle at all till i un plugged the mass air, never saw a code.
94LTZ May 29, 2012 11:25 PM
Also same thing happened when my fuel pressure regulator took a shit.
1_MEANZ28 May 29, 2012 11:33 PM
maf ,o2's,bent pushrods,valves ..my project camaro suffers the same thing ur describing and these are the bads..car mas over revved damaging pushrods ,possibly valves
ahritchie May 30, 2012 08:38 AM
It's probably the optical sensor itself of the opti which took a shit....not the cap and rotor. Have the PCM scanned..there may not be an engine light or even a code stored unfortunately. From my experience, it's best to replace the whole damn thing while your down there unless you are just doing general preventive maintenance on a properly functioning opti. Unfortunately, your 93 car has the old un-vented opti like my car which is known to give more issues than later vented versions due to moisture buildup. (How old is your opti?) I got a very lightly used MSD opti (which is vented) that has performed flawlessly and cured a constant 5200 rpm miss caused by the old opti; something to consider since you probably have to dump some $$ on a good opti.
© 2026 MH Sub I, LLC dba Internet Brands
