ICM cooling mod quick Q's I've been having a missfire/bogged feel so i just did this with instruction from shbox's site. I used four 3/8" washers on each stud (the evap hose bracket is missing) when i took off the coil/icm bracket i noticed it had a little damage. its a poor quality pic but the "fins" are a little bent. is something i should worry about? or does it not matter? http://i47.tinypic.com/2h4x5s5.jpg Also, in this pic from shbox he has the wires and the ground strap both on the right (outboard) stud. on mine the wires were on the left(inboard) stud and the ground strap was on the right stud. i just put them back how they were originally but are they both supposed to be on the right(outboard) stud? (both studs are the same length) http://i45.tinypic.com/2ywilns.jpg Is the connector for the coil supposed to have three metal things to make contact for the three pins in the coil where it plugs into? mine only has 2... http://i48.tinypic.com/351v9qs.jpg The finished product - almost 3/4" of space http://i46.tinypic.com/2hnb3wp.jpg |
The fin damage is of no real consequence. The grounds can go to either stud. Later models may be different than my 95. Two pins are all that go to your single connector coil. |
Originally Posted by shbox
(Post 16415542)
are you still stock t-stat and cooling fan turnon? |
Originally Posted by BadBirdie
(Post 16415575)
just the man i wanted to stumble upon this thread! thanks alot for the info my friend. those fins are just for cooling correct? thanks again! |
Originally Posted by trilkb
(Post 16416424)
| All times are GMT -5. The time now is 12:35 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
