won't start hey, guys was washing car today. moved it to vacuum it, it started fine and moved it. then when finished with it, was going to leave for work. but it wouldn't start, it clicked once when I turned key to start it. what can it be.? the starter? An FYI, I out a jumper on it and same outcome Posted from LS1Tech.com App for Android |
I used* a jumper on it and had the same outcome. Bump, need help figuring this out. |
Did you spray the engine bay at all or under the car? I would start by checking all of your grounds and making sure they are tight and have a good connection...start at the battery and go from there. |
no I did not spray the engine Posted from LS1Tech.com App for Android |
Do the lights come on, dim? check your battery cables at the battery |
was the starter Posted from LS1Tech.com App for Android |
| All times are GMT -5. The time now is 07:00 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
