relocation bracket issues
Old Sep 13, 2012 | 07:29 PM
pillarpod's Avatar
Default relocation bracket issues
I started one in the suspention section but know this get way more traffic in here
https://ls1tech.com/forums/suspensio...l#post16719217
Old Sep 13, 2012 | 07:46 PM
TwoFast4Lv's Avatar
Looks like the whole housing is bent from the pic you posted!
Old Sep 13, 2012 | 08:21 PM
duh's Avatar
duh
I had the same issue. My pass side relocation bracket sat crooked as well. I used a hammer and tapped it up a bit. Then I just used my impact gun to tighten it up. IIRC it is still sitting on a slight angle. I wouldn't worry about it too much. And I know my rear axle isn't bent.
Old Sep 14, 2012 | 08:01 PM
nitrous2fast's Avatar
I would take it off and measure from the one side top hole to the bottom hole on the opposite side(criss-cross). Then compare that measurement to the exact opposite. If they are the same, then the two side pieces are square and you shouldn't worry.
