Percy's header gaskets
Old Oct 30, 2012 | 07:30 AM
SS RRR's Avatar
Village Troll
Using a metal gasket greatly reduces the margin of error when it comes to a true surface. It's obvious from the gasket none of the ports were sealing. As already stated you need to find out if your flanges are somewhat flat by putting a straight edge across or you need to make sure your header bolts are tight. I'd completely stay away from metal gaskets IMO.
Old Oct 30, 2012 | 12:33 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Are the copper gaskets layered? Do they crush when you tighten the headers down? I've never personally seen copper gaskets, but I've always imagined them being like a penny, which may not be the case.
Old Oct 30, 2012 | 12:48 PM
SS RRR's Avatar
Village Troll
I believe I used copper once and it was a single layer. The area around the ports were raised to they would crush when the flanges were tightened. Can't remember if that is entirely true or not...
Old Oct 30, 2012 | 02:06 PM
speed_demon24's Avatar
Originally Posted by 96capricemgr
I haven't tried the other options being discussed but I know I like the Earl's Pressure Master.
I think the material is similar to the remflex but it is inserts in an aluminum frame.
This. These are the runs I'm running.
http://www.summitracing.com/parts/EAR-29DD3BERL/
