Dave357lt1's build thread This is going to be my third combo with this car. I'm starting from scratch and replacing the entire drivetrain. Engine -Advanced Induction Trickflow 21* 212cc heads -Custom Advanced Induction billet cam -Advanced Induction ported and milled intake -.30 over -Comp. Ultra pro mags NSA 1.6 rr's -Chromoly pushrods from Advanced Induction -Stock Crank -Stock rods -Forged pistons -ARP rod bolts -ARP studded mains -New LS7 lifters -Herron Performance billet oil pump drive -Standard oil pump with pickup braised onto the pump -Dynaspark Vented opti -LLP knockoff headers w/ 18'' extensions and turndowns -MSD wires -CSR (JUNK) EWP -Low mount alt. - A/C Delete -Power steering delete - Moroso Crank Case ventilation system -6an coolant crossover Tranny -PTC TH400 W/RMVB -PTC 10'' 4K Stall -Hurst 1/4 stick 2 -6an lines -Big ass Flexalite cooler -Madman dipstick -Stange Chromoly driveshaft Rear -S60 -3.73 gears -Lightweight spool Suspension -BMR TH400 conversion crossmember with tourque arm mount -Spohn Adjustable tourque arm -Spohn Lower control arms -BMR LCA relocation brackets -Double adjustable panhard bar -CE rear shocks (i got for nothing to try) -Front shocks are stock looking to buy some single or double adjustable -BMR subframe connectors -No cage till the track kicks me out -Manual conversion stock rack from rackDr -Draglights Other -I bought BOLO's NO2 setup -I have done most of the free weight reduction minus door bars -Greg Rob mail order/data log tune -ABS delete -Line lock -Ozite light weight carpet Short term goals are low 11's N/A Long term goals are high 10's N/A and High 9's on spray Its prob. a week or two till its first startup. Depending on how busy work gets. Id like to be making some passes by February before it goes back to 90*/100% humidity. |
Nice Dave!!! Looking forward to hearing the progress! |
Looks great.. Wats the specs on the cam if ya dont mind. |
Originally Posted by TravisMcGill2000
(Post 16964704)
Looks great.. Wats the specs on the cam if ya dont mind. Small duration. But A.I.'S combos work great with them. Kinda wish I went solid roller but there is always next time I guess. |
Seems like all ai cams are specd lot smaller than le's. Im running 236/244 on 110 and im wondering if its gona peak past 7000k.. Im lookin forward in seeing ur results. |
I had the same cam in my old combo as urs and hated it. My friend emailed L.E. and he said it was to big for his 383 but speced that for my 357. |
Sweet baby Jesus! |
looks great whats the car weight u think |
Love this build! How come you didnt go 40 over to keep with your username? |
Originally Posted by unioncarpenter84
(Post 16967357)
Originally Posted by bufmatmuslepants
(Post 16967403)
ya itll be 700-800 pounds lighter than factory specs thats alot |
Love those valve covers! |
Originally Posted by cprmn14
(Post 16967593)
(Post 16967593)
Subscribed. Looking good so far!! |
Looks good so far!!! I got the polished valve covers like those. Been thinkin of blackin out under the hood like old school muscle cars to play off the 396 LTx :) You gonna hide wires & fuel lines while your at it??? Keep the pics comin!!! |
Ohhhh nice. I know this car. Can't wait to see it fire up. |
come on lets fire it up already. I need some LTx fix so I get motivated to get mine going. Its only been 3 years.. |
| All times are GMT -5. The time now is 05:45 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
