m6 10 bolt with 4:10 on street tires?
Old 02-11-2013, 08:40 PM
teal94z281989's Avatar
also how do i kno what series i have? im guessing 2 series?
Old 02-11-2013, 08:44 PM
draggin97s10's Avatar
i have to agree to disagree with the installer being the problem with aftermarket gears whining! I was a tech for about 4 years...certified in gears....Not that, that means ****, But i have noticed with cheap aftermarket gears are more likely to whine and that gm gears are quieter. Just my two cents. Set up several sets and have destroyed several sets.
Old 02-11-2013, 08:45 PM
Not to mention MOST aftermarket sets are factory rejects
Old 02-11-2013, 08:54 PM
ramair 1's Avatar
I agree draggin on the aftermarket sets ,but allot of the time it is the installer or DIY that is the issue.O.P. find out if you car came with and that will tell you if it came with a 3.23 is a series 3 carrier if its a 273 then series 2
Old 02-11-2013, 09:28 PM
i bielive my rearend came with 3.42 from factory. its a 94 z28
Old 02-12-2013, 01:22 AM
Gmanstan's Avatar
Go with the 4:10's they'll last if you dont abuse too much & you'll get to use 6th gear. I have them in my DD ,and perfect for street/freeway,at 80-85mph I average 26 mpg+ on long drives ,before the gears I couldnt even get to 6th gear without luggin' the motor.
Old 02-12-2013, 04:01 AM
Rob94hawk's Avatar
Anyone know why this Motive 3.90 ring and pinion set is $400 and the rest are half this?
http://www.summitracing.com/parts/mgr-g975390
Old 02-12-2013, 06:47 AM
bowtienut's Avatar
"cheap aftermarket" - I'd say you just may have a point there
Someone above mentioned Richmonds being loud. I don't consider Richmond cheap aftermarket, have plenty of experience with them, and every set has been quiet.
Old 02-12-2013, 08:28 AM
Village Troll
SS RRR's Avatar
I've always seen complaints about those who use Richmonds having noise problems. I've just always thought they were a more finicky gear to set up. Seems everyone who's had a good installer has always been happy with Motive gears. It's what I have in my 12-bolt now and it's quiet as stock.... until the harmonics kick in and it gets transferred through the body from the chassis mount torque arm.
Originally Posted by teal94z281989
ok thanks for the advice i think the 3.90 would be a good choice. i will make sure before i leave the shop it has no whine cause in my opinion there should be no noises at all after any gear install.
Not sure how often you go to the track, but if you don't then spend the money on the 10-bolt as suggested and don't worry about a heavier duty diff. If you do go to the track then I wouldn't spend a dime on what you have now and save.
Old 02-12-2013, 09:37 AM
guppymech's Avatar
Speedinc wants $190 for that same gearset and that has been their price for the last couple years.
Old 02-12-2013, 10:00 AM
jesup16's Avatar
I've had richmond's and now have motive's. Installed by 2 different experienced mechanics...both are noisy.
I'd recommend GM parts if you can find/afford them.
Fool me once, shame on you. Fool me twice, shame on me!
Old 02-12-2013, 10:04 AM
  #32
I have installed two sets of richmonds and they have been quiet as could be...
Old 02-12-2013, 11:31 AM
  #33
i dont go to the track at all yet but like i said i wont abuse them since i hear to many horror stories about them shattering. im just gonna get the 4.10s, ta girdle and master install kit that should last me awhile as long as i dont pop the clucth.... whats the break in process for these puppys???
Old 02-12-2013, 01:24 PM
  #34
nitrous2fast's Avatar
Dont forget the solid pinion spacer. It will keep the torque from pulling/pushing the pinion too far.
Old 02-12-2013, 05:31 PM
  #35
ok where can i find a solid pinion spacer?
Old 02-12-2013, 09:49 PM
  #36
http://www.summitracing.com/parts/rat-4111/overview/
or
http://texas-speed.com/p-2449-ratech...5-10-bolt.aspx
Old 02-12-2013, 09:59 PM
  #37
thanks everyone for the help. I greatly appreciate it
Quick Reply: m6 10 bolt with 4:10 on street tires?
