How do you feel about the LPE 211/219 cam for my daily driver?
#61
Seriously, as stated above, go shorter.
Faster you get to OD = less rpm = better mileage. Which results in a happier performing baby cam car.
4.10's are almost "mandatory" on even lightly modded M6 F-body's. These cars have been out for 24 model years now. You're not going to discover some magic recipe at this point, especially on the LT1.
Now, I am torn between the 2.73 and 3.23 gears. The 3.23 would be a safe bet, but the 2.73 is what seems to be better suited for my driving style. Once I am working again, I think I should just pay for a used Firebird 2.73 rear axle and have it thrown on my car and try it! I won't get rid of the 3.42 axle, just in-case I am proven wrong. I will say this, I will not be able to tolerate the 4.11 gear on my car! I don't get my thrills trying to drive my car like I am at the track! I would rather have the 2.73, or 3.23, and just stay in one gear when I do open up the throttle when it's safe to do so. Yeah, it's corny, but again I don't take her to the track and she is basically my good looking daily cruiser instead of a full-fledged race car.
I am only going as high as the 2.73, but nice joke.
#62
..well OK, its your car
going to 2:73 or even 3:23 is not what anyone else would do...but again its your car
Assuming you have 3:42 (IIRC M6 came with that gear) and you want a "long" gear and keep rpm under 2k in your normal street driving (read holly F lets lug the motor and load it up)...just leave in 2nd gear and shift into 4th under normal driving. Your clutch will take more wear doing so...just like with 2:73 gears
This way there is no cost to "have someone throw in a 2:73 rear end", reprogramming so speedo is accurate
Also you would still have a low enough gear (1st) for up hill take off....or God forbid in cases when you actually need to get the car moving faster....a need that can occur in "traffic".
#63
I am a little fearful of the 2.73 from all the negative comments I am reading, but there are a few who have survived with these rear axles as temporary fixes for replacement racing axles and they claim it is not as hard on the engine as is claimed, but you certainly won't shoot up to the stars as fast with your tachometer, but again, my car spends more time in the low to mid RPM range and for my "launches", she will need more power in the low to mid-range. This is why I am trying to make her a "torque-monster" in this spectrum and why I am choosing higher rear axle gears to apply this power to.
#64
The speed at the RPM ranges from gear-to-gear is consistent with a 3.42, but again I prefer to have my tachometer slowly reach 2,000 or even 3,000 before I have to shift. Now, I tried driving from second gear and my car really did not like it! It sounded like something was bad with my transmission as the engine certainly sounded bogged down until enough engine torque kicked in at 2,000 RPM and I was shooting off into 30mph. This certainly felt like "lugging", my engine sounded like it was grinding so I will refrain from doing this again! As I see it, driving in second with a 3.42 is not going to be the same as driving in first with a 2.73 rear, or better with a 3.23 rear!
#65
I really need to have a 2.73 rear axle thrown on my car to see how bad you all claim it is. I don't drive my car shifting in the high RPM range, I shift it very low in the city and when entering the expressway I will ride the tachometer to near red line. So, how bad will my clutch hurt with the 2.73 the way I drive my car when I often have to ride it for traffic idling slower than my car idles on first gear?
This decision is not set in stone and I could end up going for the 3.23 rear axle. Either way, I am not happy with the 3.42 and I want something higher! The 3.23 may be it to save some acceleration and to marginally improve 6th gear high way mileage. Fair enough?
#67
Well, I suppose my rear axle swap in the next few years should be a used 3.23 axle then. I don't have my heart set on an axle swap to a higher gear for mileage sake. I am modifying my car to suit the kind of driving I am doing and the low range shifting I make. So, I will settle with the 3.23 rear axle. Hopefully with my transmission gearing, it should produce the effects that I think the 2.73 would have produced without prematurely wearing down my clutch or accelerating too slow.
#68
Village Troll
Now, I have read all the opinions of M6s using higher gear ratios and yes, for highway it will bump up your mileage, if you keep the RPM down! From driving around town in lower RPM, the 2.73 gear ratio should better help me keep my RPM below 2,000. In playing around with a gear ratio/transmission speed calculator, I should be able to get away with using the 2.73 without problems of lugging my motor, I have mastered the feather foot technique.
My question is, why would my mpg be so shitty in town when the car is just lugging along compared to the open freeway where the car is running a consistent 2400rpm for four hours?
#69
City MPG is always lower than FWY as you are constantly "accelerating" in city/stop & go driving. Fwy you usually just have a lower steady gas pedal to maintain speed so you get a higher MPG on FWY
#72
Phoenix,
You need to keep the stock 3.42 gears given your current goals. They provide a good balance of gas mileage, rpm, and gearing for "spirited driving" when needed.
At this point, you really need to listen to what these guys are telling you unless you like wasting your time and money.
However, given your mentality so far, you may need to get one of these to go with the mods you are considering.
#76
Village Troll
Have another question Phoenix'97. Perhaps you can clear it up? Today I was driving one of those fancy cars that has instant MPG readings. Was on a road with a crosswind. Once I happened upon a large vehicle like a semi it would block the crosswind and MPG would improve by 20% or more all the while remaining at the same RPM. Why?
#77
For a mild cam it is perfect. I only have experience with it with ported heads. Ran it in my car for over 80,000 miles with no problems. It peaked at 5800rpm, put down 370rwhp and 350rwtq with accommodating mods. Ran 12.09 @ 115.5 for a best with a 1.70 60' in a 3750lb car. Got 27ish/22ish MPG. I think you'll be real happy with it for what you're looking for.
#79
It's quite possible these days. There's a sticky dyno thread at the top of this forum which may be worth looking at as a reference. As far as gears, I forgot about a 3.23 ratio. Not sure how that would suffice with the two cams which are pretty much referred to as RV cams. Meaning they produce Nebraska Oak pulling torque at low rpm and have a short power curve. If it were me with an auto I'd live a little and go with a 3.42. Your acceleration with the torque produced at low rpm will be outstanding.
I would like some more acceleration versus what I am getting out of my car, and I would really love to get as much power out of my LT1 that I can using a mild custom grind camshaft modeled after the crane 227. I will also consider what you said about mild ported heads for my application, and I may even revisit the notion of using a cross ram EFI throttle body intake on my motor since the goal is maximized lower to mid range power since the car will spend most of it's time in this range. Then, to have a custom true dual exhaust using an H-pipe to finish off and complete the magnaflow sound.
Of course, I need to weigh my options! If all of the above modifications will cost me MORE than the cost to swap in a 2014 LT1, then I seriously need to consider it. I love my car, I enjoy driving her daily, and I am realizing how to improve upon my joy when driving her.
#80
Phoenix,
