Had to change valve covers...??
Old May 17, 2013 | 01:03 PM
Quazz's Avatar
Default Had to change valve covers...??
So because of the heds and the valvetrain setup, i ended up having to buy and use a set of Canton Fabbed Covers.
Unfortunately, this means that my OVC Wire set from CCperformance will no longer fit.
I picked this up today at the store:
http://www.jegs.com/i/Spectre/865/18483/10002/-1
Think they will work? The wires themselves are just too short to fit up over the cantons. What do you think?
Old May 17, 2013 | 04:41 PM
96capricemgr's Avatar
You do know stock valvecovers can be trimmed to work with wide body roller rockers right?
Some Proforms will clear shaft mounts.
Of course if you are going girdle then none of that helps other than to say by the time you buy good studs/guideplate/rockers/girdle you could have at least considered shafts and the cheaper ProForm covers
