ok camaro fans who thinks i made a bad choise
Old 06-08-2013, 06:00 PM
1bad96camaro's Avatar
Default ok camaro fans who thinks i made a bad choise
I have a 96 z28 it had a lt1 with a 6 speed car had blown head gaskets I fixed then and that day the motor started knocking. so out it came I ended up listening to a buddy and putting a carbureted gen1 sbc in it with a th400 trans car makes 600hp on spray and leaves like a monster what are you thoughts on carbed or FI. good decision or bad
Old 06-08-2013, 06:07 PM
pillarpod's Avatar
what'd you pay for the car then?
Old 06-08-2013, 06:08 PM
I got it for from my dad when he passed it was stock
Old 06-08-2013, 06:24 PM
Zlow28's Avatar
A lot depends on you. There are very few(if any) advantages on carbureted over fuel injection. Ive had a motorcycle that was carbureted, and i hated bothering with it in the mornings or cold starts.
IMO, FI > carbs, but if you already have the new engine installed and working fine, i would just leave it alone.
what size shot are you running?
Man-Crush Warning
Shownomercy's Avatar
Race it.
Old 06-08-2013, 06:42 PM
96capricemgr's Avatar
If a dedicated racecar then whatever floats your boat. If this is supposed to be a street car then this was stupid as the carb and th400 both make pretty substantial compromises on the street.
LT11996's Avatar
Plus the distributor is going to be a major PITA to work on with it being behind the cowl. 600rwhp? Or 600fwhp? Sounds pretty fun either way
Old 06-08-2013, 07:03 PM
600 fwhp and ya the hei is a bitch to work with but I cut all the way up to the windshield and the motor was dropped and moved forward a few inches I took it to the track once and I couldn't hook my 60 ft was 2.129 I ran a 12.60on street tires on motor and that was with 342 rear end gears I just put 410 in and got a set of 28.10.5 slicks so will see where I land now
Old 06-08-2013, 08:53 PM
pancho toco loco's Avatar
I take it this is just a stripe car that sees very little street time? 4.10's,slicks, spray? I see a new rear in the future
Quick Reply: ok camaro fans who thinks i made a bad choise
