94 Corvette - runs great, dies, won't start, starts, runs great, dies, repeat...HELP!
Old 08-29-2013, 12:00 AM
BigPeter's Avatar
Default 94 Corvette - runs great, dies, won't start, starts, runs great, dies, repeat...HELP!
A month ago, I came into a '94 6M Corvette (there's way more info about me and the car here - https://ls1tech.com/forums/lt1-lt4-m...ease-help.html)...
A week ago, apropos of nothing, the car died while idling. Then it would only crank, but not even try to fire. Waited a minute - tops - tried again, it started, revved, and ran as if nothing ever happened. One day, a few hundred miles, and dozens upon dozens of start-ups later, it happened again, this time in 6th on the freeway at 80+...actually, while still in gear it read maybe 300rpm on the tach but the pedal was unresponsive, and it obviously died as soon as I depressed the clutch pedal; once stopped it was the same as before, except this time I got pissed and just kept the key turned and the starter cranking; 30-ish seconds of this got me a really low, shaky, unhappy idle that died if you so much as thought about the throttle, but would restart into the same >500rpm idle...left at this unhealthy idle for 30-ish seconds it caught and revved itself to 2500 and then fell to normal idle within 5-10 seconds, then drove as if it never happened...various versions of this have happened with increasing frequency until today, when the car was good for 1-5 miles of perfectly normal driving before dying and requiring increasingly longer wait times before it'll re-start. Not good.
Currently accepting all ideas, experience(s), opinions, prayers, etcetera.
Thanks in advance!
-Peter
Old 08-29-2013, 08:13 AM
shbox's Avatar
When it won't start check for presence of spark and proper fuel pressure (with a gauge).
Old 08-29-2013, 09:34 AM
Village Troll
SS RRR's Avatar
Now that it won't start it will be easier to diagnose if it's spark or fuel or both. Do what shoebox says.
Old 08-29-2013, 04:03 PM
KW Baraka's Avatar
Pull one spark plug from each head.....and let us know if anything 'unexpected' happens.....
KW
Old 09-07-2013, 09:33 PM
BigPeter's Avatar
The car gods were/are smiling upon me...turned out to be nothing but a simple ignition control module. And in addition to not randomly dying, an added (and quite possibly placebo effect-esque) benefit is that it feels cleaner/smoother off idle and near redline. Either way, we're back!
Old 09-08-2013, 07:24 PM
projectbirdshot's Avatar
I was reading along and knew it was the icm immediately lol. happened to me the first time i got to operating temp after i rebuilt my motor. needless to say I was a bit distressed. glad you found it!
Old 09-08-2013, 08:56 PM
Motorvation's Avatar
Sounds a lot like my problems, only I've swapped the ICM with my Nephews car, his runs, mine has the same damn problem.
Old 09-09-2013, 06:39 AM
bufmatmuslepants's Avatar
To prevent future issues you can do the ICM cooling mod and space it away from the head slightly with washers.
Quick Reply: 94 Corvette - runs great, dies, won't start, starts, runs great, dies, repeat...HELP!
