10mm spark plug wires ? Good or bad
Its time to change plugs and wires on my lt1(has a small misfire) .
I bought ngk tr55's and ebay "high performance " 10mm wires.ivd had some 10mm on a old lt1 i had ,but i got it that way.ivd been told i am going o run into some problems installing them.
Car has stock manifolds.
Any input is appriciated.
With the bigger wires I had to run two longer ones on the 6 and 8 cylinders, I used some fiberglass boots to keep anything from burning. The drivers side is easy to run but it gets a bit tight getting anything over a 8.5mm in the stock locations thru the passenger side.
