LT1 Braking issue
Agreeing with 97, the rear calipers need to be checked and made sure they're in good condition.
Power bleeding is the best way to do these jobs. Find a brake shop and have them power bleed them. Make sure they flush out the old fluid.
If the problem persists, at least you'll be able to rule out air in the lines. At that point, the shop should be able to guide you in the right direction.
