Nitrous Questions Lately I have been having the urge to get nitrous on my car. Doing some reading, I think I want to just run a small 75 shot. Like all of us I'm on a budget and I have a few questions. 1. What's a good cheap beginner kit? I've heard good things about ZEX 2. What other "accessories" would I need to run with it? Window switch, WOT switch, etc? 3. Does the Fuel pump need upgraded with such a small shot? I actually have a new stock replacement one in there now and also a new fuel pressure regulator (if that even matters) 4. Anything else I'm missing? |
1. Not 100% sure for the these engines. I'm sure someone else will answer it 2. Window and WOT switches, remote bottle opener, bottle heater, purge, fuel pressure safety switch, master switch, bottle psi gauge, bottle blanket, etc. Obviously not all of this is needed, but these are possible accessories that you could use to make your system more effective/safe. 3. Stock fuel pump is fine 4. Read http://www.go-fast.org/z28/new_to_nitrous.html, http://www.sccoa.com/sccoo/Faq/nitrousoxide.htm, and http://www.competitionplus.com/05_20...n20_myths.html Those three links are very helpful in terms of info on nitrous and using it. The first one actually covers Lt1s and LS1s. Hopefully those help you out |
1. I would recommend Nitrous Outlet. Not the cheapest but when I was spraying, I really liked their kit. 2. A WOT switch is mandatory in my opinion. For a manual car, a window switch is recommended. 3. If your fuel system is in good running order, it should be fine with a 75 shot but these cars can take a 100 with no issue (I know folks have sprayed more). I would recommend a hot wire kit for the fuel system. 4. These are not mandatory but I usually like to know what is going on. I would pick up a wide band A/F and fuel pressure gauge. You should step down to a colder plug (like a TR6) and make sure you are not running platinum plugs. Lastly, find a way to retard timing when you are spraying. |
Thanks for the responses guys. I'm basically just wanting to know what I need to get me started cheaply. What's a cheap starter kit? What are the COMPLETELY neccessary things that I need to get started? I can always buy the extras later on. Would a simple kit like this work: http://www.nitrousexpress.com/6107/1...lb-bottle.html |
defiantly dont wanna go cheap with nos. if you do your motor can blow and that wont be cheap too fix. that kit would work. I just finished their universal efi kit. real easy to wire up. I am also fairly new to nos on lt1s. do research on an ignition boxes like mallory 685 or msd 6AL box. the mallory has a built in window switch setting and pulls timing. going to colder plugs is a must. when its all said and done your looking at alittle over 1000 to spray safely. |
I ran Zex. worked great, easy install. i ran 100 shot and no ignition retard was required. i highly recommend the window switch, the kit comes with the WOT switch. |
i upgraded my fuel pump but its not required. |
So let me know if this sounds good. Nitrous kit: NX Proton Plus #20421-10 Timing and window switch: Mallory 685 Spark plugs: TR6's Does this all seem good? At least to get me started spraying? Or am I missing something? |
if ur getting the mallory box, get the msd wiring harness($35) for the 6al box. it will make it alot easier to wire up the box. dont need to cut and splice your factory harness. ill be installing my box soon so if you have any questions pm me and ill do my best to help. Wire up the nos system first and install ur plugs. make sure you have everything wired up correct before you put the box in. also if u dont plan on spraying, un plug the weather pack connector (ull see once u get the box) and plug in the bypass that is included with the box. if you leave it plugged in, it can lower ur opti life http://www.ls1lt1.com/forum/n20-tech...questions.html a diagram that will help with the yellow/orange/violet wires on the box. when you get th box youll understand http://www.ls1lt1.com/forum/n20-tech...ultispark.html post #5 has the msd harness part number and how to wire it to the mallory box. hope this helps |
Do I even need to pull timing for just a 75 shot? Car has bolton's, hotcam and madtuner tune. |
Yes. Sure u probly get away with it. Why chance it tho. I would swap to a non projected tip plug instead of the tr6s. I think there the br6efs. |
Nitrous outlet plate kit window switch bottle warmer purge kit external fuel pressure guage or electronic gauge if you want inside bottle blow down tube safety bypass kit This will give you a safe reliable nitrous system, most kits you see are not complete kits and will need a few more items for your application. Listed above has a reliable solenoid kit that's extremely important. It does not matter if you run 50 or 200 shot you should make the system safe incase something goes wrong, like failed solenoid's, low fuel pressure etc. A good ignition and fuel system is a must or your next thread will be building a new motor. |
No timing pull needed for a 75 or even a 100 shot. Some recommend it at 100 but my Impala never changed whether I retarded it 4* or not. I ran an MSD Digital 6, an MSD digital window switch, WOT switch and a 150 shot with no issues. I pulled 6.5* timing and could run it all night long with no issues. One of the most important parts is having a good bottle warmer with the automatic manifold to turn it on at 950 and off at 1100. I love the idiots that heat bottles with propane torches. Then by the time they stage, their pressure is back down to 700. A better fuel system is highly recommended. But I ran mine with a stock AC Delco pump and never lost any pressure. There's an infamous Racetronix thread here-a-bouts and Ed Wright got up to 500hp on his stock pump never missing a beat. |
If your not pulling timing your playing a game you will lose sooner or later, every 50 pull 2 degrees. Your not building a race car that you only drive at track. Do it right or pay l ater |
Originally Posted by 96TransAmboosted
(Post 17996414)
Well since zex is the cheapest pos system on the market I would not trust there word over a manufacturer like NOS ever. You should be 4 degrees retarded for a 100 shot will it work not doing that yes but how long and at what cost in the long run? So go ahead and do whatever you want it's not my motor at risk |
Technology for nitrous has come a long way since my first time playing with it 30 years ago. Pulling timing is always recommended but the right addition of fuel is the key. You can run a 100 shot dry and be fine. Just make sure your injectors are good. If running a dry shot, a FPSS is very highly recommended. I also suggest the window switch. Do yourself a favor and kick in the extra few bucks for the digital box. |
Originally Posted by SAPPER
(Post 17997980)
Originally Posted by Wallj
(Post 17998334)
I'll be running a wet kit. I was planning on running the NX Proton Plus kit with a Mallory 685. The kit has a WOT switch and the mallory has a window switch and can retard timing. So I should be set after I get colder plugs. Is a bottle warmer really necessary? |
Bottle heater is a must imo , the new bottle bracket heaters are pretty bad ass. |
© 2024 MH Sub I, LLC dba Internet Brands
