Speed Engineering LT1 Stainless Longtubes Now Available!!
Old 04-16-2014, 07:56 AM
  #61
WCT13's Avatar
Originally Posted by big hammer
looks like you broke off your coolant sensor when installing the headers like I did.
shhhhhh, don't remind me! Actualy we broke it when we pulled the motor. we super glued it back together and it held until i hit it. probably gonna super glue it back again.
Old 04-16-2014, 08:05 AM
  #62
big hammer's Avatar
lolz
Old 04-16-2014, 11:47 AM
  #63
ThoR294's Avatar
looks legit
Old 04-16-2014, 02:37 PM
  #64
WCT13's Avatar
Originally Posted by ThoR294
looks legit
What looks legit?
Old 04-20-2014, 04:53 PM
  #65
WCT13's Avatar
finally got it all done.
This was a problem on the drivers side. the collector was right in the way of the bottom of the car.
Problem solved.
Next...the y-pipe for an LS on a LT. The y pipe itself fit rather well, we didnt have to cut any pipes at all. The only problem is the clamps didnt seal the connections well so it leaks now.
This is the connection from the 2.5 Y to the 2.5" exhaust. We went to advance and bought a 2.5" ID pipe and it slid inside it, so we clamped it down and it worked.
The steering knuckle was rubbing on the header so we pulled the knuckle off and hit the pipe with a hammer, problem solved!
This was also a problem, this connection slid out when clamping the exhuast down, so we slid the pipe back from the collector to give us more length to the connection and we clamped it down.
After this is all done, we are going to get a shop to weld ALL of the connections cause you can hear the leaks. But on a scale of 1/10 on the headers, 9/10! The y-pipe fitting 7/10 but it DOES fit.
Old 04-20-2014, 09:57 PM
  #66
Sponsor
Speed Engineering's Avatar
Glad to hear...
1. We will look into the Knuckle issue. It could also be warn out motor mounts. Either will look into it.
2. Usually we recommend cutting a 1" slot on each connection point on the Y-Pipe. It allows the female side to clamp down on the male. We plan on having that revised down the road, but it should get rid of most of your exhaust leaks.
Sounds like the LS1 Y-Pipe fit for the most part. Thank you for taking the time to test everything out for us. Appreciate it..
Thanks
Sean
Old 04-21-2014, 07:40 AM
  #67
smitty2919's Avatar
Thanks WCT13 for the install pics. I just came in here to ask if someone could take pics of it installed.
What does spark plug access look like on driver side and passenger side? Can anyone get a pic?
Also, be careful with those band clamps facing "down". Rotate them 90* so they don't catch on anything.
Old 04-21-2014, 10:32 AM
  #68
WCT13's Avatar
Spark plugs are better then the manifolds. You can reach 1,3,5(if you have small hands), and 7 with little effort.
Now, the pass side is a diff story, still, better then manifolds, if the start is off, you can reach 4,6,8 and you have to do 2 from up top.
The clamps are just temp, im prob going to get it welded on so I dont have to worry about them.
Old 04-21-2014, 11:01 AM
  #69
smitty2919's Avatar
Well I already have Pacesetter L/T's but was curious how the routing of these pipes may differ from other brands.
Can you snap a pic from the top on both sides?
I loved my GTO with L/T's....that pipe routing gave you amazing room. But then again, different engine and engine bay lol.
Old 04-21-2014, 12:32 PM
  #70
WCT13's Avatar
Any more requests just lmk!
Old 04-21-2014, 10:40 PM
  #71
big hammer's Avatar
errrbody has their temp sensor smashed off.
Old 04-23-2014, 01:14 AM
  #72
MasterTomos's Avatar
In for more updates.
Old 04-25-2014, 01:39 PM
  #73
Village Troll
SS RRR's Avatar
Originally Posted by WCT13
Problem solved.
Hopefully after your BFH art, you've put a few coats of paint on it to prevent rust...
Old 04-25-2014, 01:50 PM
  #74
transam_man's Avatar
Will they fit with the rest of factory exhaust or will I need a y pipe
Old 04-25-2014, 11:10 PM
  #75
Sponsor
You will need Headers & Y-Pipe to connect to your factory exhaust.
Thanks
Sean
Old 06-25-2014, 09:06 PM
  #76
ThoR294's Avatar
What looks legit?
the headers and Y pipe
Any update on the install issues WCT13 had, Speed Engineering?
Also...
http://www.ebay.com/itm/LT1-Camaro-F...e=STRK:MESE:IT
"LT1 Longtube Headers (Camaro & Firebird) 1998-2002 F-Body "Stainless""
should probably change that to 93-97
Also, I noticed...
http://www.ebay.com/itm/LT1-Camaro-Firebird-Longtube-Headers-Y-Pipe-Race-Version-O2-Extensions-/261459438597?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce0326c05
$430 is a great price. I hope to do this soon... way cheaper than some other brands (~$200 less than someone else making them that I know of...)
What about placement of a cat with this? I assume the cat would go right after the Y? I would be using one for NJ inspection to be happy. They just plug in and check under the car for a cat from what I can tell
Old 06-26-2014, 10:24 AM
  #77
rjc1629's Avatar
I'm thinking about picking up a set of these, anybody have any updates on how they are holding up? Any other installed pics of the y-pipe connection?
Old 06-26-2014, 06:58 PM
  #78
WCT13's Avatar
Mine seem to be doing great! Y-pipe is now tack welded together with slp right out the back. It wouldnt hurt if you had a welder to weld it together...
BUT the steering knuckle issue, I took the knuckle off and grinded down the oval part where it was rubbing, works like a charm now!
Old 06-26-2014, 07:02 PM
  #79
rjc1629's Avatar
Cool, good to hear. I have a welder so I can tack it together no problem. From the pics it looked like the pipe used to connect the y to the catback was angled a little. I'm looking at putting a highflow cat in that spot so I'm not sure if that would be a problem or not.
Old 06-27-2014, 03:16 PM
  #80
ThoR294's Avatar
Would a ls1 knuckle help?
Quick Reply: Speed Engineering LT1 Stainless Longtubes Now Available!!
