Put LT1 up on jacks, now won't start 1994 Firebird LT1. Had the engine running in the garage, started lifting the car with my jack (passnger's side first) about 15". The engine stalled out when I had the right side in the air, and I didn't think much about it, figured it was starved of fuel or something... Proceeded to lift the other side, and left it alone for a couple weeks... Today I go to start it (no tires on, still in the air) and it'll turn over all day but it won't fire... Any ideas why??? I should mention that after it stalled out I didn't touch it for about a week. Today I completed an oil change on it, but nothing went sideways, no wet opti, etc... So I'm pretty sure lifting it one side at a time affected something. |
Check for crushed fuel lines? |
Originally Posted by 1fastrock
(Post 18184717)
You either crushed some fuel lines or you were low on oil and the low oil sensor got triggered and shut the car off (I believe that's how it works?) Are you that low on gas? |
Originally Posted by 93M6Formula
(Post 18185327)
There's almost a full tank of fuel. I'll double check the fuel lines. |
(Post 18185453)
Low oil sensor is an idiot light only. PCM does not care how much or how little oil you have. |
Is the fuel pump running? I had a '88 mustang that had a 'roll over' switch that would turn off the fuel pump. |
(Post 18185911)
I was just curious because it also does not let you start your car when it doesn't sense oil. I was distracted one day when I changed my oil and forgot to put oil in and it wouldn't turn over, filled with oil after I realized I about fucked over my engine and it fired up then. |
Originally Posted by SS RRR
(Post 18185962)
Makes no sense after all the "my car is running with no oil pressure" threads that have popped up over the years. I do not believe the oil sensor is connected to the PCM in any way. |
(Post 18188374)
Then my car is a freak because it wouldn't send power to the starter until I added oil..... |
when my oil pump drive gear broke my car didn't shut down or prevent me from staring it |
Originally Posted by mab6680
(Post 18188900)
Originally Posted by guppymech
(Post 18185922)
Is the fuel pump running? I had a '88 mustang that had a 'roll over' switch that would turn off the fuel pump. I thought as well that it may be a rollover type switch. How did you get your mustang pumping fuel again? |
Originally Posted by Dadic 78
(Post 18191340)
When I turn the key to "on" I'm pretty sure I can hear the fuel pump fire up. I still haven't had a chance to get back to check it out for crushed fuel lines, etc... I thought as well that it may be a rollover type switch. How did you get your mustang pumping fuel again? |
OP confirm you have fuel "pressure" |
Have you checked the yaw sensors? The angle could be extreme enough to make them fuzzy and cut out spark to the opti which means your starter wouldn't engage. |
Originally Posted by BALLSS
(Post 18191698)
(Post 18191718)
(Post 18191927)
What's the best way for me to do that? (Sorry, haven't done ANY fuel line work in my past!). http://www.jegs.com/i/Hypertech/533/...FY6RfgodzbcAug the hose screws onto the Schrader valve on your fuel line rear of motor. It will have a cap on it that looks like a large tire valve cap. some auto part stores may have them as a "loan-s-tool" deal. A good tool to have in your toolbox. |
Well I've just spent the afternoon in the garage. Inspected for crushed fuel lines, and found none. All seem to be in good shape. Interestingly, the fuel lines run along the left side of the car, and the engine stalled out when I lifted the right. I still haven't had a chance to get a fuel pressure guage, that's probably going to be my next step. Can anyone confirm if there's any sort of rollover sensor in this vehicle? Or something of the sort that may be causing a no spark condition? And if there is one, how to reset it? |
| All times are GMT -5. The time now is 07:41 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
