exhaust manifold bolt GRR
Hello
I have all the exhaust manifold bolts out except the 2nd one from the back on the drivers side. it almost seems like the head is rusted off but it didnt sheer
any idea what to do, i tried turbo sockets and that didnt work
thanks
thanks
i sprayed all of them a few days ago rellly well. they all came out w/o much fight and this one i cant even get a grip on it, yea i tried one of thsockets with teeth, is it possable that the head is a different size than the rest?
If it's one of the bolts with a little rusty collar/spacer between the bolt head and the manifold then you're in luck. Grind the head of the bolt off with a dremel so there's nothing but a stud left. You'll be able to remove the manifold now to gain more access. Then you can either back the stud out using 2 nuts torqued against each other (what I had to do, recommended) OR grip the stud with some vise grips (last resort, will damage threads).
