Moroso Oil Pan
Moroso Oil Pan
So the plan is to toss on a moroso pan and the associated parts and just wanna make sure i purchase the right stuff.
Pan: Moroso 20185
Pump: Melling 10554
Pickup: Moroso 24213
Anyone see anything wrong with these parts? Standard volume high pressure pump along with the f body specific pan and pickup.
Pan: Moroso 20185
Pump: Melling 10554
I just finished gathering these exact parts for my 396 build. I am running the 20185 pan with the 10554 pump. Moroso does not make a pickup for that pan with a 3/4" inlet. You need the Canton 20-013. That is a press-fit, 3/4" inlet, standard volume pump pick up. It only took me three tries to get the right pick up!
With everything installed, there is 0.400" clearance from the bottom of the pickup to the pan.
