A/c high pressure valve?
Does anyone know if the high side port on a 94 camaro lt1 has a removeable shcrader valve or do I have to replace the whole line since it is leaking at the port? Any help is appreciated, thanks.
This may sound stupid, but listen. A/C on houses mostly is one of my things. Schraders are SERVICE PORTS, they have caps with O rings/small rubber seals for a reason.
Schraders leak a little usually, not like a hiss but a very minute leak. Make sure you have the caps on with the seals intact.
I was going to gas on and on, but, change it if you can, and make sure you have the caps on an the cap seals are intact. Caps are cheap
