Car shuts off randomly... Any thoughts?
I just bought a 93 firebird formula with 86,000 miles on it and it randomly shuts off when I drive it. The first few days I had no issue then now out of a sudden car will randomly shut off after a short time of driving. The times that this has happen to me time varies before I can start the car up again some times I can start it again instantly sometime it takes 20 mins to a hour before I can. I haven't noticed anything wrong with the car driving wise it will drive good then just shut off randomly. Anybody have any idea what could be going on?
Starter is ingauging I feel like it might not be getting any spark I've been told most likely it is the optispark starting to go bad it's random though I drove the car all day today with no issue. I bought a new optispark today and plugs and wires. The car has 86,xxx and I'm assuming all that stuff is still original I'm just worried about changing all of that and it still having that random issue.
What brand optispark did you get? This is important.
If no spark only, check icm and coil. Maybe cap and rotor.
Verify fuel pressure. Should be 40ish psi with the key in the on position, spike to 43-47psi with the vacuum reference pulled off the FPR, and after the car is shut off should take quite a while to bleed down.
Could be the optispark as others have suggested, but unless you're sure that's the issue its one of the most over-blamed parts out there.
On My 3rd gen Z28 the ICM would do that & I pulled it out & put new dielectric grease on the thing... Never done it again... The 4th gen is a totally different animal LoL the Security VATS bullshit can Drive Ya Nuts!!! My firebird was doin stuff pretty close to what your explaining... I ended up replacing the key switch because the wires were broke on the thing... After I did that I found this site & the VATS delete how to thats the way to save yourself some Headaches!!! Google or search on here for VATS bypass or VATS delete... its Easier than the key switch lol You can turn it off in the PCM if you have tuning equipment... After that if its not runnin test the Opti harness , ICM & coil
