Optispark Failure?
Optispark Failure?
So I just got done receiving my 4th revision from Solomon on getting my car all tuned in on E85. Car is really starting to run strong so I decided to take a friend for a ride before putting the car away for the night. I was going to drop the car off after doing one pull but decided to do another 1-3 run cause the damn thing is just hauling the mail. Well I run thru first, hit second, hit third, wind third all the way out to about 68-6900 rpm on the tach and the car just nose dives and shuts off. Car would not even think about firing once I get it pulled in to a industrial complex. When I popped the hood I got a faint smell of burnt electronics. Before heading to grab the trailer I pulled a plug wire and it had no spark. Once I get it back to the shop I pull the coil wire off going to the opti and there is plenty of spark and looks healthy. Do you guys think that points to the opti? I think the high RPM took it's toll and killed it. Makes me laugh cause my buddy that I took for a ride asked me if I was still going to the track this Friday. I told him before heading to pick him up that I wanted to but the car is running so damn good I don't want to break it lol. Let me know what you guys think.
Also, should I get a MSD unit or a OEM? The OEM unit is almost $700 dollars on Jegs!!!
EDIT: I don't know what Opti I saw at first but one was listed at damn near $700. Now I see one for right at $500.
Sounds like the Opti....but you may want to verify that all the signals are okay going to and from the unit(reference 5V, high res, low res, etc) also...are the injectors firing? Best to troubleshoot it thoroughly before buying parts.
RockAuto has an AC Delco reman for under $400. Strangely, it's not listed under the 1997 models.....only 95/96. I was going to recommend a new Delphi, but interestingly, there are no Delphi units on their site anymore.
I would go with the AC Delco reman before anything else....but reman doesn't generally sit well with me in many cases. However, it's the only option for an AC Delco unit now.
I've never recommended anything but AC Delco or Delphi, but I do wonder(in light of new supplies drying up) if MSD has finally fixed what was going wrong with their units?
Something like a 24x conversion is looking appealing, but with mine being a '96, emissions stuff could be an issue.
Alright thanks guys. The injectors are working and my fuel pressure is unchanged. I put loctite on the rotor screws and sealed the whole unit together with silicon. I do have good spark from the coil to the opti. The car got revved a little higher last night than normal due to running the E85. It just revs cleaner so I let it keep going. I am going to order the cap and rotor kit that was suggested and if it looks ok I will send it back. Sound like a ok plan? I think I am going to tear into this weekend and get it going. Don't want to hold Solomon up. Car may be done now though after the 4th revision. Feels perfect.
Wow, it either snagged one of the terminals or something was bad in the way it mounted to the rotor(and then just let go). I'm not sure I could tell which it was, but I don't see any bent terminals. Does the metal tip that spins over each of the terminals show any damage on the end of it? I do see a little discoloration on the tip, but that might be from voltage normally arcing.
This an AC Delco unit?
96capricemgr actually called it first. I just agreed. Just about any time you are in a high RPM situation and the engine suddenly shuts off or backfires, then shuts off, it is a rotor failure. If they are going to let go, it is in that situation.
I would suspect that where the inner plastic pin is dark, it had been working its way loose for some time.
I wouldn't go so far as to say that. I've NEVER had an AC Delco ABITS unit fail on me....and I've had my '96 for 16 years. I'm on my 2nd opti and the first was pulled at ~100K when I did my cam swap. Nothing wrong with it at all. I currently have it boxed up as a backup.
That's not to say they are perfect, but, to my knowledge, they have a much better track record than any other opti manufacturer to date.
Aside from that I said the cap and rotor not the base with the optics.
