Do you need an OptiSpark? 2 yr Warranty!
Restore spark to your LT1/LT4 motor with this BRAND NEW Distributor from AIP Electronics
This Distributor EXCEEDS OEM specification and comes 100% complete with everything needed including a new Optispark wiring harness.
(Note: Harness may not fit all applications and you may have to use your original harness.) Our AIP LT1 Optical Encoder is temp rated at 330°
and produces an accurate timing reference signal up to 8000 RPM, exceeding the OEM Mitsubishi encoder used in the AC Delco factory LT1 distributors.
This is most likely the best aftermarket LT1/LT4 distributor you will ever come across. Uses AIP's own Mitsubishi Specification Optical Encoder
for the most accurate/dependable LT1 Distributor yet. (All Info From AIP)
We have negotiated with AIP and from now on AIP Opti's come with a 2 Year Replacement Warranty ONLY when purchased through SacCityCorvette!
Vented $159.95
Non Vented $169.95
http://www.saccitycorvette.com/AIPOptiSpark.html
Vented $159.95
Non Vented $169.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
We have them in stock if you need one.
__________________
2 Year warranty when purchased through SacCityCorvette!
__________________
