If someone could give me a quick yes or no on optispark
1995 Trans-Am. Just replaced opti, water pump, plugs, wires. Has a Moroso cold air intake. I'm to the point of installing the air intake. Found the "fresh air vent" to my opti and I don't remember disconnecting. The air intake was on when I purchased the car 6 months ago. There is no hole anywhere in the intake so I'm wondering if it was ever hooked up?
I found this fitting under the throttle body and don't recall removing anything from it so I'm also wondering if I should plug it off?
Should I just drill a small hole through the rubber boot downstream of my MAD and plug in the fresh air tube?
Here's the end of my fresh air tube. Can't see any sign of where it went if any
And I found this which looks like nothing has been hooked to it. At least I have no parts left over and can't find a hose bent out of the way as if it had been disconnected.
Here's my Moroso intake. No holes anywhere for this small tube to plug into
I did something similar on my old LT1s. It was worth it!
http://www.msdignition.com/instructi...pdf?terms=8381
Yeah my hoses are different sizes. The vacuum is larger so everything appears to be lined up. I just cranked and she fired right up, idled fine, no leaks. Was waiting for temp so the thermostat would open so I could vent it out the top bleeders but she heated up to the red. Now I'm scratching my head? Radiator full. Thermostat not opening? Extremely thin bead of rvt on thermo housing so know I didn't goop it up. Suggestions?
