1996 wreck camaro wiring questions
I bought a wrecked 1996 Z28 that hit a pole where the wires go to the cab and I am wondering if they are needed for the starting of the motor in a motor swap to a C10?
Depends on which side it is (you don't specify). There is wiring on both sides. The engine harness wires (the ones typically used in a swap) go into the interior on the RH side of the car, under the computer.
http://shbox.com/1/harness.htm
