'95 LT1 won't start
'95 LT1 won't start
Just got my Camaro back together after performing the following mods:
Any suggestions on where I should look?
Thanks,
Jim
- LE2 cam/heads
- Trick Flow 58 MM TB
- 32# Delphi injectors
- PCM Tune
Thanks,
Jim
After I wrote the post, I started to consider a head gasket failure. I'll be checking the compression tomorrow. It's going to be a challenge getting the fitting into all of the spark plug holes. Gonna be a bummer if the heads have to come back off.
Did you loctite the rotor screws in the opti?
Sounds like what happened to my car a few hours ago. I'm actively putting my 24x shopping cart together.
In short... it sounds like your opti is done for. FWIW, my motor was completely rebuilt less than 5,000 miles ago (looks brand new, squeaky clean) and I've developed a very slight oil leak on the front of the timing cover. These opti's seem to be so sensitive that even the slightest bit of debris will cause them to stop functioning.
The only other thing you can check is for whatever reason, a hot opti is always less happy then a cool one. If you let it sit overnight, and try to fire it again, it may run for a short while and then die again. If that is the case, it would confirm my suspicions.
The problems you describe in short seem to depict a complete failure of your optispark. Additionally, you've troubleshot all the likely culprits already so unless you have some bizarre 1 in 1,000,000 issue, its probably time for a new opti. Or, do some research on a 24x kit. After a few hours of research, it seems like the up front investment is worth it to stop the endless hemorrhage of money on optis.
The compression test showed no problems - readings were between 155 and 170. That's a relief. Can't remember whether or not I used Loctite on the rotor. I've looked into the 24x conversions but I'm kinda invested in the OBD1 platform with cables, data logging and programming software. I do have a spare Opti that was working when I took it off another motor, so I may try that just to verify that is the problem. Any other diagnosis I can try before I start pulling it apart?
Are there other fuel tests to run besides pressure and bleed down? My plugs were gas soaked when I pulled them for the compression check so I'm pretty sure I'm getting fuel.
if the plugs were fuel fouled, I'd be looking at the coolant temp sensor. When it goes bad, it tel the pcm it is -40 and it will dump a ton of fuel to compensate for what it thinks is a cold start. Unplug the sensor in the water pump and see what happens. You can also pull the fuel pressure regulator line off and see if it has fuel in it. If it does, the diaphragm inside has torn and you need to replace it
I think your wet plugs further indicate a dead optispark. Sounds like your fuel system is operating correctly and when you are cranking, you're dumping fuel into the cylinders but with out spark, your essentially just fuel soaking the cylinders because of the lack of combustion. Try a spark test on one of the cylinder wires if you want to confirm.
Got it running - the optical sensor was bad in the distributor. The inside of the distributor was dry but there was some sign of oxidation on the steel parts. I had another distributor with 150K miles on it that came off a running motor. Pulled that one apart and the inside was spotless and it had the Mitsubishi sensor. Put everything together (with Loctite) and it fired right up. It's idling better too. Need to find another backup now.
I've owned this car since new and it's the first time I've had optispark problems.
Thanks for all of the input.
I did, but I just checked it on cylinder #1. Had a nice blue/white spark. Between that, the injector pulse indications, and all of the proper voltages at the opti and ICM harness, I thought it was something other than the opti. Just got back from a test drive and it's running pretty good.
The spark test is unreliable, I had a problem once where the car wouldnt start, I pulled the #1 plug to check for spark and firing order, the plug would fire on the compression stroke and had a blue spark, after all checking, I replaced the opti and it fired right up...I believe there is a procedure on ShoeBox where he has steps to test the opti..
I used Shoebox's procedure to verify voltages, resistance, and continuity at the ICM, Opti harnesses and coil. All tested within spec. It wouldn't run until I swapped out the optical sensor in the distributor.
Car fired up great for 18 years. Problems started last summer. Left the #2 plug wire off and had trouble starting..obviously. Put it back on and all is well. Few weeks later hard start strikes. Only when cold. Warm all is good. Drives great, no problems. No codes.
Park it for winter storage and no start at all. Fuel pressure looks normal, plugs are wet with fuel and I see spark on the plug. Will investigate further. Hope it is not the Opti but I have a Versafueler and bigger injectors.....maybe fuel pressure regulator but FP looks good...seems like the spark is getting drowned out.
Dunno, sorry for the thread hijack.
If you've checked everything else, it might be the optical sensor. My understanding is you need an oscilloscope to check one with any amount of certainty. I've got it down to where I can swap one out in about 2-3 hours.
