Fuel Pump
Old Aug 11, 2016 | 05:48 PM
ak422's Avatar
Default Fuel Pump
So I take everything out and I accidentally drop this piece in a puddle of water and its soaked. Is that ok or should I let it completely dry out before starting the car? Or would I have to replace the whole piece?
Old Aug 11, 2016 | 06:11 PM
kingtal0n's Avatar
I think if you dry it should be fine. Let it plenty of time to dry maybe pass a fan over it for a while. Im not sure what that is, a fuel vent sock? Most parts on cars can get wet, they will almost all come into contact with water at some point, in some form or another.
Old Aug 16, 2016 | 02:07 PM
ak422's Avatar
I was thinking of replacing it but cant find anything online. Any other suggestions?
Old Aug 16, 2016 | 02:33 PM
BALLSS's Avatar
if you are talking about that filter sock, just put it in a small container of gas and shake it some to clean it and then let it dry..although you can put it back in wet...it is submerged in fuel anyway inside the tank
