pcv fresh air hose check valve
Instead of putting a catch can on the clean side of the pcv system, could i put a check valve so when at wot no oil works its way into the intake?? Already have a catch can on the driver side
Village Troll
The "fresh air hose" is actually called a breather tube. Meaning the airflow within the hose is neutral. That is for the supply of air when the engine is under vacuum and is a means to evacuate normal blowby when the engine is under load. Just leave it alone.
