Low Oil Level Light Only Occures Once per Start Up
Old 05-06-2017, 07:25 PM
nowoodywagon's Avatar
Default Low Oil Level Light Only Occures Once per Start Up
I have a 96 Roadmaster. Its all stock, I drive it every day. I am assuming this is a ground issue, because....I broke all the grounds on the left cyl head taking the coil off. I have replaced the oil level sensor, twice. Did not fix the issue.
Start the car up, drive it down the road....no lights on the dash. Get in the gas about half throttle and when it reaches the first to second gear shift point the low oil level light comes on, engine sputters, the light goes off, engine picks back up and continues on.
Repeat the same action with the throttle application (with out turning the car off) and it wont do it again, shifts and runs good under load.........but then will idle poor and hesitate off idle.
I have not seen another thread on any forum with that specific issue of it only occurring one time per start up. I have re-done the ground 3 times on the left cylinder head. I am to the point of tracing wires back unless someone has gone though this already.
Old 05-10-2017, 08:17 AM
smitty2919's Avatar
Oil sensor is a dummy light, that's why you have a dipstick. Verify oil level is fine via dipstick.
Then put a resistor in the harness plug and move on to figuring out why the car stumbles.
Old 05-10-2017, 10:59 AM
Village Troll
SS RRR's Avatar
No resistor needed. Just a jumper wire. I have an office staple plugged into mine.
Old 05-10-2017, 11:18 AM
smitty2919's Avatar
Bah, you're right. I'm thinking of VATS bypass.
Old 05-11-2017, 08:25 PM
Sorry, I forgot to mention I already jumped the plug. Still has the same issue.
Old 05-12-2017, 07:26 AM
smitty2919's Avatar
You jumped the harness plug and still get a low oil level light? That's odd.
Old 05-12-2017, 10:47 AM
Village Troll
SS RRR's Avatar
A wire from the plug could be damaged.
Old 05-12-2017, 11:13 AM
smitty2919's Avatar
That's what I'm thinking or the jumper wire is not contacting the terminals correctly.
Old 05-12-2017, 12:08 PM
I cut the wires behind the plug and tied them together. No change in the symptom. I didn't think it would change anything the sensor is new. I am starting to think the ground is cut but one would think it would do this every time on a hard shift not just once per start up. I hate to ignore it because when I tow some heavy throttle sometimes is nice to be able to use.
Old 05-12-2017, 01:02 PM
smitty2919's Avatar
Again, use the dipstick and ignore the idiot light. These sensors typically cause more issues than they help. I had an oil leak though the body of the sensor. I simply found an adapter and use a oil temp gauge from that pan port now...no more leaks.
As far as the studder on acceleration, that may be something different.
Old 05-12-2017, 03:58 PM
The engine shutter is directly related to when the oil level light comes on. the sensor is looped. and the oil level light comes on and the engine cuts out until the light goes off. Looking at a dipstick isn't going to help anyone right now.
Old 05-12-2017, 09:02 PM
shbox's Avatar
Sounds like a wiring issue...maybe some touching together? Any rodent activity? Gotta be something wrong with the wiring to the low oil sensor, since the loop does not fix it.
Old 10-14-2018, 10:48 PM
Rashin Farley's Avatar
Default Mine too
Did you ever find a solution on why this was happening? I have a 94 Caprice that is doing the same thing.
Quick Reply: Low Oil Level Light Only Occures Once per Start Up
