Car too loud! help!
Old May 20, 2017 | 07:58 AM
Webatron's Avatar
Default Car too loud! help!
I have a 94 Camaro Z28 bone stock with a LM1 cat back. I just cut out the catalytic converter because it's gone bad 3 times in the past year i've gotten the car and I'm sick of replacing it over and over again. My problem is that the car is so freaking raspy now and sounds like a tin can. What is the best muffler I can put on the car to quiet it down and get rid of the rasp?
Old May 20, 2017 | 09:06 AM
myltwon's Avatar
If you're looking to just replace the lm1 resonator I believe the moroso spiral flows or the Magnaflow round muffler will be your best options for noise reduction.
Old May 20, 2017 | 10:41 PM
shbox's Avatar
If you killed three cats in one year, you have some engine running issues that should be addressed.
Old May 20, 2017 | 11:24 PM
96lt1m6's Avatar
Dynomax ultraflow bullet
Old May 21, 2017 | 08:50 AM
Badazz 97 TA's Avatar
Magnaflow is pretty tame and sounds good at full throttle. It really comes down to preference. YouTube will be your best bet to narrow it down to what you like or would prefer.
Old May 22, 2017 | 12:53 AM
KW Baraka's Avatar
This, this and THIS!
KW
Old May 22, 2017 | 09:57 AM
SS RRR's Avatar
Village Troll
What is your setup on the car? Any other modifications done besides exhaust? Are you still running the AIR pump? LT1's are notorious for burning extremely rich when cold. The answer was to run an AIR pump which channeled fresh air into the exhaust to help the catalytic converter heat up more quickly.
