1997 Camaro LT1
1997 Camaro LT1
My car is a V8 6 speed w/skip shift eliminater added.I would like to know what gear ratio I should go with for street without any major modifications,I don't mind getting lesser highway mileage,I want more ***** when I get going.Also any suggestions on torque converter.
you can go online for a rpm calculator selecting rear tire size, rear gear and what gear in the T56 (1-6) to see what your rpms would be in any given gear at x speed
I have 4:10 & a 27" tall tire and my rpm is 19xx at 80 mph
on the street its a 4 speed, highway 5th and I generally don't shift into 6th unless maintaining 65 mph or more
many feel 4:10 is the ideal gear unless you get into running a much shorter tire....then 3:73 may suit your driving more
You will need to get the PCM reprogrammed so your speedo is correct with different than stock gears
