Jacking the car's front, what do you use as the jack stand points?
Old 06-20-2017, 09:14 AM
ShovelMan's Avatar
Default Jacking the car's front, what do you use as the jack stand points?
I cannot find any info on where to place the jackstands when replacing headers. Thanks. I will be doing this job in a week or two.
Old 06-20-2017, 09:30 AM
Village Troll
SS RRR's Avatar
I think all I've ever used are the points where the lower a-arm connects to the k-member.
Old 06-20-2017, 09:58 AM
PyroguyFTW's Avatar
Probably not 100% correct, but I use my subframe connectors where they bolt into the subframe towards the front. I can lift the whole car that way, but usually I just take up the front and put a jack stand under the mount
Old 06-20-2017, 12:25 PM
The Batman's Avatar
Currently my car has two jack stands under the k-member
Old 06-20-2017, 07:32 PM
timaishu's Avatar
I am curious as well. I have been placing them on the subframe but I can see over the years the previous owner has dented them slighly. And since my jack stands are the u shaped ones, only two of the corners make contact, so during my month of owner ship I have been using that spot and leaving the jack in place taking about half the weight.
I am curious where you guys place your stands with the u shaped cup where nothing will get bent.
I am considering these for the subframe locations I use, I think this would be perfect.
Amazon Amazon
Old 06-20-2017, 07:40 PM
96lt1m6's Avatar
Front, I like to place the stands under the lower control arm close to the tire.
Rear, I place them under the axle tubes depending on what is being worked on I will put the stands just ahead of the lower control arm mount.
Always think safety and take a fullsize spare and toss it under the car so if the car falls it won't fall far.
Old 06-21-2017, 07:12 AM
smitty2919's Avatar
Front, either on the frame right before it bends upwards into the fender area or on the K member under the oil pan.
Rear, I always use the rear shock mounts/axle tube. Unless I need to work on axle to let it hang I use the frame. I always jack up the back using the pumpkin.
OP, I found this:
http://installuniversity.com/install...ift_points.htm
Old 06-21-2017, 07:45 AM
nodnarb481's Avatar
I usually place the jack stands where the k-member meets the lower control arms, as some others have said. When replacing the lower control arms last month, I placed them on that plastic jacking point behind the wheels.
Unless I'm replacing the lower control arms, I would continue to use that point rather than the body. There was noticeable flex in the body that i picked up on when I had to open or close a door. I have subframe connectors and it still flexed a noticeable amount.
Old 06-21-2017, 04:56 PM
moehorsepower's Avatar
I now put the car either on some old wheels or some ramps I have since I had a jack stand fly out from under the car at one time
Old 06-21-2017, 09:43 PM
ACE1252's Avatar
With my 2x4 stands, I use the plastic pads as you would for a post lift. Pic below.
With jackstands, I use the flat part of the subframe just behind the plastic pads. You can just see that flat area in the below pic...circled in red. For the rear, I just put the stands under the axle or I'll use my bigger jackstands under the area close to the trailing arm mounts. You can see that in my last pic below. If I'm pulling the engine....then I set the rear tires in a couple of my old salad shooters.
Old 06-22-2017, 12:17 AM
timaishu's Avatar
Not to sound like a jack *** but I am assuming you dont build that each time Jenga style? How is it all held together?
Old 06-22-2017, 10:07 AM
Purple Poncho's Avatar
I use race ramps wheel cribs on stacked 4x8s to get desired hight.
Old 06-22-2017, 07:50 PM
ACE1252's Avatar
LoL, of course not. Nails are my friend(not small diameter either). I use them for transmission and engine pulls. Below, the first 4 blocks are an adapter that I set on top of them for the engine pulls(also nailed together). I'll try to get a couple of pictures later. They are way more stable than trying to set the body on jackstands. I've only used jackstands twice to set the body on for engine pulls...and never again. Made me very nervous that they may fly out from under the car if it's moved too much.
Old 06-22-2017, 08:27 PM
ACE1252's Avatar
LoL, marvel at my stunning artwork.....
Looks like I used 8d 2.5" nails to hold it all together.
Quick Reply: Jacking the car's front, what do you use as the jack stand points?
