Can someone help me find the troubleshooting guide for electrical problems?
I recall seeing a pic that says "Check voltage on battery, alternator" etc. It gets posted here a lot whenever a person claims a problem with their optispark. I can't find it. Need to troubleshoot my alternator.
If anyone wants to take a crack at my issues:
- Driving in the rain. SES light popped up.
- Voltage dropped to the yellow-diagonal lines section (below 10?)
- When I use turn signal, the speedometer fluctuates about +/- 5mph
- Tachometer is just the same
- New Battery
- AFAIK, the alternator is probably the original alt the car came with (1993)
- New Battery
Village Troll
Don't get it tested. Test it yourself. With the engine running, put a voltmeter to the charging wire that leads to the battery and a ground source and see what the voltage is. It should be a STEADY 14.5 volts. If it fluctuates the alt. is bad. If it's lower than 14.3 volts then most likely it is bad.
I have two readings:
Using a Fluke 115 from work, I put the probe on the red wire on the Alternator's square post and the black wire on the battery's black/negative post. If this is the wrong way to do it, please let me know so that I can test it again.
Voltage (AC), I got 12.65. Voltage (DC), I got 0.364. Either that or I made a mistake and got the numbers mixed but both of the numbers I got back were 12.65 and 0.364 with no fluctuations with engine running.
The alternator has been replaced with a rebuilt Carquest one from AAP. Looks like the core used to rebuild was a REMY USA. Looks sharp, but out of place in my weathered engine bay.
Problem is solved. No more low voltage triggering the SES light anymore!!!
