Any one running a Twin Turbo LT-1 where yo uretained the A/C
dang, thanks for trying. I have a huge space where my battery used to be and all I've ever seen is guys running a Twin turbo LS1's utilizing the left and right sides (Battery and passenger side and Intake driver side spaces) to stuff the turbo's in. Thought that would be enough space to retain the A/C on the LT-1 if the turbo's lived in those spaces instead. But when I see twins on the LT1 I see guys mounting them in front of the Opti or small turbo's running off the sides but with NO A/C and the alternator relocation kit.
Not that this has to do with anything but I thought this was interesting...
http://www.jegs.com/i/Banks/139/2110...UaAsCuEALw_wcB
This is the only Lt1 with twins that retained AC, I may be incorrect. Jim Moran
https://youtu.be/9fGQiIlyHTM
Negative, just did some searching he deleted the A.C.
http://www.fquick.com/garages/viewvehicle.php?id=3636
From my memory, his car did retain AC. This profile page confirms it.
I was so amazed at how clean his undercarriage was I forgot about the rest of his car as beautiful as that engine setup was it took 2nd place to that clean *** underbelly. Makes you ashamed to look under your car. Set that as a new goal 1. Super Shiny undercarriage. Mine is dirty and complete with that half painted drive shaft tunnel where GM got lazy.
true!
easy to keep a/c if you plan on terminating the DP's in front of k or fender exits. It's squeezing past the k with two pipes to run to the back that's the problem.
Now... if you merge the two DP's into a single 4" to squeeze over the k and past the steering linkage... then you can keep A/c. Run the single 4" all the way to the catback, or do true duals. I would weld on a single 4" electric cutout before you run it down to the catback.
true!
true!
