New Engine Dyno Results!
Midwest engine tech just finished up my 383 LT1. I will post more information once I get in a laptop. Here are the results:
For some reason I can't post pictures today.. I'll try the laptop a little later.
The average was 497HP/498TQ
https://photos.app.goo.gl/my356mbTOGvFWocK2
Heads flow similar to LE1s, flat as hell torque curve! Was still making good power at 6200, what's the bottom end setup? It doesn't mention a new crank or rods in there, but the size of the cam and how it still had 500 crank hp at 6200, you should take it to the track and make runs changing the shift points starting at 6400rpm all the way to 7000 and see what gives best times, should be around 6800 im guessing. Autos kill about 18-20% so it'll be around 400 at the tire, should be good for mid to low 11s depending on the rest of the car. Congrats!
