Cometic MLS Head Gaskets C5645-027
So I’m slowly getting parts to put my 383 together and I’ve been looking at head gaskets.. I’m intrested in the Cometic MLS Head Gaskets C5645-027, but it’s a 4.040 gasket.. Would it be safe to run with them with a 4.030 piston? Any advise? Thanks..
Village Troll
I wouldn't bother unless you are going to run crazy cylinder pressure. On a street car the odds could be stacked against you and they could end up leaking. IMO run a Fel-Pro head gasket and be done with it.
HG's aren't a "Do you think this should work" part of your engine to fool around with. Match them to the right bore size. Get a quality set of 4.030 gaskets that you're setup calls for. If you're really worried about your HG's use Studs instead of bolts.
So you thkink that particular gasket will leak because of the material it’s made of? I know solid copper head gaskets leak slightly on 14:1 race engines but I didn’t think an MLS gasket would.. What would be a good .026-.030 gasket to run? All I know from Felpro is the 1074 which is .039..
That’s why I’m asking for advise.. I know how thin I need them.. Just was curious on how small a bore I can run.. And a 4.030 bore with a 4.030 gasket is asking for trouble imo..
and yes HG's or really any engine gasket can be more prone to leaking depending on what material they're made of.
http://www.jegs.com/p/Cometic-Gasket...48863/10002/-1
Village Troll
As far as thickness, a lot of people have ran the Impala gaskets which I believe are .026.
It's just like any soft metal gasket. There is little margin for error for imperfection on the block/head surfaces, and with liquid under pressure is a constant assault on any weak points. If there are any then they will be found and leak and the only solution is to start over again. As stated, if it's an N/A daily then I wouldn't do cometics. JMO, of course.
Village Troll
I have no experience with them. Everything I've ever done was with Fel-Pro. I had cometics on my last engine for about two years before they started leaking. Car was pretty much dailied at that point since it was fun to drive. Do a search on those gaskets and see what comes up.
